Need some Android help - Smart Car Forums
 3Likes
  • 3 Post By rfernatt
post #1 of 10 (permalink) Old 12-09-2014, 10:15 AM Thread Starter
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Any experts out there? Having trouble with some mp3 files not playing on the Android music player.
jwight is offline
post #2 of 10 (permalink) Old 12-09-2014, 11:03 AM
FlossyTheSmart's Avatar
Quoted: 81 Post(s)
I don't know if I'm an expert, but I certainly have experience. When you refer to "the Android music player", do you mean Google Play Music, or another app that calls itself "Music Player" (I know Android used to have a generic music player, and certain device manufacturers bundle in their own branded music players too).
If you aren't using Google Play Music, more info may be required. Some players don't have the codecs necessary to play certain files, but I've found Google Play Music is pretty good for file playback (Should be available from the Play Store). There are other players that are good as well.
FlossyTheSmart is offline
post #3 of 10 (permalink) Old 12-09-2014, 11:58 AM Thread Starter
Quoted: 78 Post(s)
No, these mp3s won't play in Google Play, the native Music Player on the tablet or in any of several 3rd party players I tried and discarded. The files were copied to an external sd card from a PC - at one point the music players would see all the files - now they only see the ones they'll play. As far as I can tell each file is a real mp3 - the only difference is the ones that play don't have any artist or album info, and no album art. Some sort of voodoo at work....
jwight is offline
post #4 of 10 (permalink) Old 12-09-2014, 12:05 PM
Quoted: 81 Post(s)
Sounds like you've done your due diligence. I assume you've tried playing the files on your PC (and they work)? The player that I would think is most likely to play the files on Android would be VLC for Android ( https://play.google.com/store/apps/d...vlc.betav7neon ). If that doesn't play the files, I doubt anything will.
If none of that works, and the file plays on the computer, you may need to re-encode the files. The amount of effort that you want to put in may vary depending on how important the files are. What's the source of the files? (Or, put another way, how confident are you that the file was generated by someone who knows what they're doing?)
post #5 of 10 (permalink) Old 12-09-2014, 12:13 PM
To the XCAPEPOD!
rfernatt's Avatar
Quoted: 68 Post(s)
Are you sure they're not .WMA files that someone has renamed to .MP3? If they were ripped by Windows Media Player, it wants to default to .WMA and pull in album art, etc. If they were just renamed, that of course wouldn't allow them to play on an Android device, but they could still play on a PC through Windows Media Player (although I would expect some type of message about the format not matching the extension).
You could try to use a free sound editor like Audacity, import the files (which will work if they are truly MP3), then export them as MP3 again (you'll need the LAME MP3 encoder, also available from the site above) if it's just some weird MP3 encoding issue. Plus, it's a nice basic sound editor, encoder.
I just spent this past weekend purging every last one of the WMA files I had to make sure that everything would play nice with my Android gear and Chromecast. Death to WMA.
jwight, chieftmc and Miss Mercedes like this.
rfernatt is offline
post #6 of 10 (permalink) Old 12-09-2014, 02:02 PM Thread Starter
Quoted: 78 Post(s)
Some of them were ripped from CDs using Windows Media Player, but they are mp3 files for sure. Someone suggested the bit rate may be a problem - I haven't checked them all but one at 320 did not play and one at a lower rate did. I'll try the re-encoding thing and see what happens. Thanks for the input.
jwight is offline
post #7 of 10 (permalink) Old 12-10-2014, 06:11 AM
To the XCAPEPOD!
rfernatt's Avatar
Quoted: 68 Post(s)
I doubt the bitrate itself is a problem, but re-encoding might help. I have a lot of Amazon purchased and other MP3s encoded between 256K - 320K and they all play fine on my Android gear. My two tablets are running Lollipop and our phones are on KitKat, so they are very recent versions of Android, but I never noticed any issues even when running earlier versions of Jelly Bean. When I rip my CDs, though, I typically use 192K as a balance between quality and file sizes.
rfernatt is offline
post #8 of 10 (permalink) Old 12-10-2014, 07:33 AM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
I've been playing around with my Samsung Galaxy 3 and can't seem to replicate the issue.
Bit Rate will not be the problem, though. All that really dictates is the overall quality of the file. Most of all my music files are 320k.
Download VLC for Android as Flossy suggested. Hands down, VLC has to be one of the best (if not the best) media player for any platform. Indeed, if VLC doesn't play it, your problem is probably with the files (Corruption? Improper encoding by WMP?)...
Miss Mercedes is offline
The Following User Says Thank You to Miss Mercedes For This Useful Post:
jwight (12-10-2014)
post #9 of 10 (permalink) Old 12-10-2014, 03:20 PM Thread Starter
Quoted: 78 Post(s)
Update: checked the tablet this morning and all the mp3s were gone - as in disappeared. The tablet did not even show the sd card as installed. Just replaced it with a SanDisk sd card, reloaded the mp3s from the PC via Kies and so far so good. All the music is there and plays with the native Music Player as well as the Ringtone Maker app - the whole point of the exercise.
jwight is offline
post #10 of 10 (permalink) Old 02-28-2016, 10:13 PM
Yes I am facing the same problem too.
ElsieWeldon is offline
KitKat is the next Android version; 1 billion Android activations rfernatt Tech & Gadgets 23 09-10-2013 05:24 PM
Free Android Apps... chieftmc Off-Topic Cafe 7 11-21-2011 05:36 AM
Smart Android Theme? jediknight36 Tech & Gadgets 9 05-25-2011 06:55 AM
