1. i forgot how long the factory coolant was supposedly good for but do you trust it or change your antifreeze every 30k anyway?
2. a temp gauge is crucial . i did this before with a secondary cooling fan. i ran the sensor in thru the end of the hose then wrapped the thermostat housing and sensor line with friction tape then put the hose on and applied a double clamp. the sensor was right in the flow stream and sensed the temp and kicked the fan on when needed. now here is the crazy part...why not do that with the outside sensor and then get a reading of the antifreeze (assuming the lcd will go that high)
