1 - 11 of 11 Posts
10Year+ Supporting Member
That is the older style GoPedal from Smart Madness. When the engine is running, it lights up according to the setting you choose. Thank you for thinking my home made installation looks "factory". I do try for neatness.
Discussion Starter · #7 ·
If it is a 451 model (2007-2014) you can consult the tome of knowedge :)
looks like I can get the coin holder out without all that work but just popping the clips on the front. I am going to install 2 or 3 switches/button switch on the front side of the console and just wanted to go thru that opening. 1 switch will to activate a small blower fan to blow cool air into the engine bay when the motor is turned off (for about 15 minutes). The second will be to mute or turn on/off a backup alarm (like trucks). And, another would be a push (momentary on) switch to inject water/alcohol into the air stream after the air filter. This is a long topic but it DOES work and makes a difference with no harm to the motor, I have used this setup many times. If anyone wishes to discuss or ask questions please PM me.
How about adding a switch to pop the rear hatch?
~toaster
1 - 11 of 11 Posts
