I just acquired an 02 cabrio. Its got 27k on it. It seems to be a G K conversion from what info I have attained. The local MB dealer cant help unless its an 08 or later. I had the starter rebuilt and was told there didn't seem to be anything wrong. I have had some real difficulty locating any sort of wiring diagram to be able to check for power and ground. Also it keeps popping a 25 amp fuse for the starter. I have traced the wires I could locate and found no short, hence the starter rebuild attempt. Any leads would be so helpful.
Sincerley,
Jim
Administrator
Welcome to SCoA! :)
I think an '02 is too early to be a G&K car; if it is G&K it should be an '05 or '06.
If you can find a local shop that does Mercedes work and has a STAR computer that would be ideal - they should be able to read any faults in the car. You should consider a subscription (around $13US) to https://www.evilution.co.uk/ as well - lots of good technical info on your version of the smart.
