1 - 9 of 9 Posts
Hey Gang,
My Mom's car has a rough idle when starting up after its been sitting for a while.
Basically if it has sat for a few days, the symptoms are this..
Turn key to the on position.
Wait a few seconds and then turn key to start car.
Car starts up good.. about 7 seconds or so afterwards the idle goes down very low, motor shakes from low idle like it's going to die, get a couple "pops" from the exhaust, and then the idle goes up to normal.
This seems like it's only on start up after a few days... after it's warmed up, it doesn't happen.
Fuel is 100 octane and fresh.
Any ideas on what could be the cause of this?
Thanks again!
Rob
How many miles on the vehicle. Might be bad plugs, dirty fuel injectors. 100 octane fuel?
Something wrong with a start up sensor. For the fuel injectors, when the vehicle is started cold. Since modern cars don’t have chokes anymore. The cars computer not sending out the right information.
Thank you all for the replies!... and my apology on the octane level, it is 92 octane, not 100
I'm going to do a minor tune up at Christmas time ( new plugs, oil change, filters ).
The car has 58,000 and is driven rarely.
Would an OBD2 show these codes you speak of?
Sounds like injector issues/start up sensor area..
Thanks!
Rob
Check for the dreaded P030x code - x being the cylinder that may be misfiring. Usually a symptom of a burned valve. :)
P030x can also be caused by a bad plug, a bad coil, or even poor compression on that cylinder too. :eek:
1 - 9 of 9 Posts
