Fixed up a 2008 for a friend and the seat belts are twisted. Guess the seats were removed and belts removed from the seats. I fixed the belts so they are correct on the shoulder and lap.
The seat belts bolted to the drivers side has a hex bolt (with spacer and washer) and the passenger side a torx bolt. On a 2015 both sides are torx bolts.
Looked online at sale ads but can't see the bolts (low resolution pictures or no pictures that low).
Can anyone check the next time they are hop in the car to see what bolts they have?
Thanks. I just found it weird that both sides were different bolt head types and since the belts were twisted; thus, assuming they were removed just double checking the last person working on it didn't replace the bolt with a non standard bolt.
Goggles,
Very odd. The shoulder bolts on both seats in my ‘08 Passion are the same 17mm bolt. I think you are right - someone must have had them off before and replaced one with the Torx bolt.
