21 - 35 of 35 Posts
Discussion Starter · #21 ·
I took it to another place, they said because the passenger seat was removed the weight moved. Now this place sat's I need a/c compressor and condenser $2,800. I found parts on amazon for $200. They only use their parts and will only rebuild the compressor. got a offer of 3,500 from a guy with a shop here. I my have to that way don't know? At least they found a code.
Computer Wood Rectangle Font Personal computer
Oh, so the AC on your smart had never worked since you bought it? What year is your smart again?
Discussion Starter · #23 ·
$1,000 your safety, or life?
Back home I have a 66 right hand drive triumph spitfire my wife has a 66 mustang gt 350 and we have 2 harleys I'm 74 I raced modified sportsman, demolition derby and raced for Honda, Triumph and harley. NO air bags, Cancer is what's killing me (smoking).
Discussion Starter · #24 ·
2009 A/C always worked till the car sat unused. I never had one problem with this car. My carfax said I drove it 880 miles per year. It was only driving in and around Boston. In Boston I had 4 cars 3 motorcycles. I retired 24 years ago with too many toys! All my cars have battery disconnects and trickle charges used on high end cars.
I quit smoking 25 years. Nasty habit.
That doesn’t sound right. The B1002 is likely a faulty temperature sensor or damaged wiring. It’s above the passenger footwell and is relatively easy to access. The connectors are somewhat fragile and can break causing this issue.
^ I think it’s built into the actual unit according to the service manual on the wiring diagram.
I’ll look in the car and see if that’s one of the typos I’ve seen in the manual.
I just feel really bad for jlbishop. I have a MB Star. If I were closer, I would go and try and fix it myself.
This is unrelated to the jlbishop's problems. I read that you have a MB Star, I would be happy to drive to Upstate NY, to have an intelligent person explain my car's issue with reverse.
On hot days, either it won't go into reverse or it will make repeated thuds before finding that gear. I've lived with this for 6 years and I actually try to find a hill to park on so I don't need to use reverse.
I would like some clarification for my own knowledge; "... the weight moved"? Is this saying the seat sensor was moved to a new mounting location when the seat was out?
As a side note: another Smart car owner told me he made the mistake of turning on the ignition when the seat was out, and afterward it would not go over 10 mph. Does the CAN put the car into a slow/safety mode as well as turning on the light, or did this person have other problems as well?
It’s likely multiple issues that they had.
I’ve never heard of a air bag code limiting overall top speed.
Transmission code yes air bag code no.
Discussion Starter · #33 ·
When the went to the dealer he was to replace the driver side seatbelt. He replaced the passenger one instead, to do this he had to remove the seat. Then he replaced the drivers side. They told me the light was still on and no codes. They wanted to start replacing parts. I took it to another place they pulled a code. I have 3 wks than I lose my garage and I'll just put it up for sale.
I drove 500 miles this weekend love the car but in Fort Myers nobody works on them. I come from Boston don't know anyone here.
Discussion Starter · #34 ·
I drove 75 to Miami this weekend did 500 miles no problem.
That’s good.
One thing I noticed since I got me a second smart for a couple projects I have planned so there is a sensor attached to a box on the end of the passenger side seat belt(had me puzzled) I didn’t know where the wire plugged into till I looked at the seat in both cars as it plugged into a connector on the outboard side of the seat near the back right side(it would be obvious)
There is also a box on the underside of the seat that the passenger detection sensor goes to(I didn’t know if the box as I figured it all when the sr’s module.
You may want to just carefully remove the seat and check this connections.
21 - 35 of 35 Posts
