1 - 3 of 3 Posts
Dear Friends,
The rear right light on my smart is not working, no illumination or turn signal.
There are two bulbs in the bulb carrier within the rear lamp housing unit.
The top bulb does light but the bottom "back up light" doesn't.
I examined both bulbs and they seem different.
Alas, before I could jot down the lower bulbs specs, I lost the burned-out lower bulb when it fell through the bottom of the rear lamp housing unit.
The top bulb is 12 V 21/5 W
What are the specs on the bottom bulb ?
Thank you very much!
JEM
2009 Smart ForTwo Stock Light Bulb Sizes Chart
Low Beam Headlight Bulb Size: H7 or H7 LED
High Beam Headlight Bulb Size: H7 or H7 LED
Parking Light Bulb Size: 2827
Daytime Running Light Bulb Size: N/A
Fog Light Bulb Size: H11 or H11 HID Upgrade Kit or H11 LED Headlight Kit
Front Turn Signal Light Bulb Size: 7507
Rear Turn Signal Light Bulb Size: 7528
Front Sidemarker Light Bulb Size: 2827
Rear Side Marker Light Bulb Size: 7528
Tail Light Bulb Size: 7528
Reverse Light Bulb Size: 7506
Brake Light Bulb Size: 7528
Third Brake Light Bulb Size: 921
Dome Light Bulb Size: 6411
License Plate Light Bulb Size: 6418
smark, much appreciated!
1 - 3 of 3 Posts
