1 - 1 of 1 Posts
Information as it becomes available.
Hotels
We have a deal with 2 hotels that are right next to each other, Nichols Inn and Americ Inn. They have reserved a block of rooms , 20 in each. The main difference is the Americ Inn has a pool and is a bit higher in cost. The Nichols Inn has 2 queen beds per room for $84.50 per night.
The blocks of rooms are reserved until 30 days before the event and then will be open to others. Make sure you mention the smart car rally when reserving a room. They are open to doubling up on rooms if that helps anyone.
Americ Inn 651) 385-9060
http://www.americinn.com/hotels/MN/RedWing?checkin=12/27/2011&checkout=12/28/2011&_rc=&rooms=1&adults=1&children=0&promocode=Promo+Code&corporate=Rate+Code/Corp+ID&group=Group+Code&travelagent=Travel+Agent+IATA
Nichols Inn 651)388-6633
http://www.nicholsinn.com/red-wing
I will try to talk to more hotels and pass on the info as I can.
1 - 1 of 1 Posts
