Is it necessary to drain the AC to replace the fan unit or is that a short cut?
S smartiecalicar · Registered Joined Jun 10, 2018 · 2 Posts Discussion Starter · #1 · Jun 10, 2018 Only show this user Is it necessary to drain the AC to replace the fan unit or is that a short cut?
jimvw57 · Premium Member Joined Sep 24, 2008 · 11,310 Posts #2 · Jun 10, 2018 Only show this user drain AC, and Coolant, remove front end frame off car.... or add a secondary fan on the front side of the radiator. hours less work and operates like original.
