1 - 2 of 2 Posts
Hello Has Anyone Used an Aftermarket Oil pan From Ebay Or Amazon? Need To replace Mine Threads Stripped. New From Smart Cost $250 Plus. Aftermarket Are Around $80.00 Just Looking To See If They Work OK Thanks Dave
If the oil drain plug is stripped, you can use Dodge truck replacement drain plug, part number 652886 (M22-1.5) it will go in farther (without the screen) and seal the washer against the pan surface. part available from most auto supply stores.
Then use a suction system to remove oil out the dipstick tube. Much easier and you don't have to mess with that darn plug.
1 - 2 of 2 Posts
