I have a problem that I haven't seen before. Hoping that someone may have an answer.
My Smart car is a 2008 451 gas powered coupe and I know a bit about that transmission, the 2015 ED version, not so much. The problem is in my Dad's 2015 ED, not my 2008.
I drove my father's 2015 Smart Electric Drive to a doctor's appointment. When I parked the car, I put it in Park then took my foot off the brake and it started rolling backwards. The shifter was pushed forward into the "Park" position and the letter "P" was indicated. So I put my foot on the brake, pulled it back into drive and inched forward again, stopped, and put it in "Park". This time it was in park and didn't roll, but I still set the hand brake. After my Doctor visit, I Got in and drove home with no problems. But when I parked it, I got an error message "!Park, Lock Inact."
The shifter is in Park as can be seen by the lite up "P"
The 2015 Smart ED has only 13,916 Miles
And in this picture is parked in the shade and yes it's 105° F. But the car had not been driven today.
My first thought was that the shift cable might be out of adjustment (or stretched due to the high temperature), but it does shift into Reverse, Neutral, and Drive with no problem.
There must be 2 sensors to indicate the gear position. One that supplies the signal to the instrument panel via the CAN bus, and one that cause the indicator lights on the shifter bezel.
Is the the ED transmission really a gear switching gearbox?
Or is it simply a gear reduction unit and the floor shifter just puts the Electric Drive motor into forward, reverse, or off (for neutral)?
My worse fear is that the Park sensor is in the transmission and the parking sprag is broken.
Anybody experience this with an ED?
