I have a 2015 451 that is seemingly starting to look like poo... I noticed water bubbles under the clear on the roof of my car after it rained. Anybody have any ideas to fix this before it gets worse? Anybody else starting to have this issue as well?
The solid roof is sort of a wrapped roof. I noticed on my 2nd Pure that it had a small tear and it would fill with water. I ended up peeling as much off as I could and used a 3m wrap on it, covering the whole roof. I used a print that looked like carbon fiber and it turned out really great looking. Not sure I would do it again, better to take it to a professional. I ended up doing it twice as I messed up the first time and cut it too short to seal the edges.
62757
The solid roof is sort of a wrapped roof. I noticed on my 2nd Pure that it had a small tear and it would fill with water. I ended up peeling as much off as I could and used a 3m wrap on it, covering the whole roof. I used a print that looked like carbon fiber and it turned out really great looking. Not sure I would do it again, better to take it to a professional. I ended up doing it twice as I messed up the first time and cut it too short to seal the edges. View attachment 62757
Thank you. I'll probably end up doing something similar if it gets much worse.
