Aloha From Hawaii fellow 453'ers!
Today our Marketing Department got some images/details about the new 453 which has an ETA of this WED (10/7) for all of you in Hawaii.
Smart Marketing Strategy: for people with a Sound Heart and Sound Mind. Exudes Happiness and a "Joy of Life" architecture.
turning circle
stick / manual side by side
Standard Features on ALL 2016 Smarts
Smart Marketing at its finest!
JBL Sound System
Dual Clutch Transmission: Triple Shaft Dual Clutch : 6 Forward Gears with 1 Reverse.
Downshifting gear by gear is NOT required because the onboard Electronic Gear Controller can Skip Gears, reducing Power Lag.
Engine Specs: Aluminum Body (reduce weight)
Electronically Controlled Waste Gate for Less Fuel Consumption
Variable Adjustment inlet Valve timing.
Square Bore Stroke Ratio.
2015-2016 Comparison
COOL DETAIL! The Honey Comb extends to the Headlight Housing!
Hope this Helps you better understand our Target marget as well as some cool details about the 453! This is only a snippet of the some 45 Pictures we received. Let me know if want to check out any others!
Smart_Hawaii
DRL (daytime Running lights) Are without the LED's, correct. but the picture is still that of a 453. Small features did get carried over :)
Nooo, but the picture of the fog lamp DRLs is right off a 451. Check out the panel gap and the valence design.
