Sent from my Pixel 2 XL using TapatalkCan you access the 453 oil drain bolt and oil filter canister when all four wheels are on the ground or does car need to be on a lift or jacked up or on ramps? THANKS. Mike700
What size is the drain plug washer? I have searched a bunch and cannot locate. I'm ordering all things needed to do my first oil change.I have a list of tools, filter & oring, drain plug washer. I lay everything out under the car in the order that I need it.
Mini (2nd gen) Seal Ring for Oil Drain PlugWhat size is the drain plug washer? I have searched a bunch and cannot locate. I'm ordering all things needed to do my first oil change.
Thanks!Mini (2nd gen) Seal Ring for Oil Drain Plug
https://www.amazon.com/dp/B0116OKGWA/ref=cm_sw_r_sms_apa_i_bQnNDb0AWG7CW
Those are the ones I've been ordering for my oil changes. Says for a 2nd generation Mini, but same size as the Smarts'.
Sent from my Pixel 3 XL using Tapatalk
My new-to-me C453 is due for an oil change soon. So I started looking for more detail information and started to order parts.Mini (2nd gen) Seal Ring for Oil Drain Plug
Amazon.com: Mini (2nd gen) Seal Ring for Oil Drain Plug: Automotive
