The tail light lens on the passenger side has a crack and hole. How do I replace the Lens? Lots of YouTube videos on replacing the bulbs but not the lens. Does the ED model use the same lens as the gas fourtwo? Thanks.
Is easy, you have to remove the back panels to get to replace them. Those lenses are held by a clip on the top and you have to unhook them on the bottom. When you unclip the top don't let it fall because you may break the plastic hook that holds it. Get another person to help you so its easier for you. I did what you said when I swapped panels last Sunday. I forgot you have to take off the rocker panels first.The tail light lens on the passenger side has a crack and hole. How do I replace the Lens? Lots of YouTube videos on replacing the bulbs but not the lens. Does the ED model use the same lens as the gas fourtwo? Thanks. View attachment 65997
