I’m hunting for a manufacturer for 3 piece wheels in:
15x7.5 +11 front
15x7.5 -11 rear
I’ve been dialing this in for years, I cannot run a larger dia rim due to lowering and width. If the numbers seem off, realize that I am running 15x6 +25 wheels spaced -55mm rear, and -33mm front. The increased width also affects the centerline by +19mm. (Rear +25, with spacers -30, with centerline offset from increased wheel width -11. Front +25, with spacers -8, with centerline offset from increased wheel width +11)
The wider wheel is actually ideal for my 195/45-15 Toyo T1r tires, and allows a little more suspension travel due to the inward angle of the sidewall.
If there is something I am misunderstanding about the construction of 3 piece wheels that would make my offset math up there wrong by more than +/- 1mm, please let me know.
Any leads appreciated.
15x7.5 +11 front
15x7.5 -11 rear
