I have the ScanGuage and watch my water temp. This week I see some issues with the water temp. In traffic I have creeped up to to 209 even saw a brief 220 one day. Didn't feel like my radiator fan was kicking on.
I trouble shot the fan all fuses relays and the fan its self seemed ok. I did the AC on Recirculate on heat on max and the fan kicked on fine. So now the fan seem to be fully functional again.
A bit low on coolant at just under the minimum line. The fan is kicking on at 213 and runs the temp back down to 185. Normal running seems to hold at 190 to 198. So I feel I am running kind of high. But now that the pressure is off, in that no need to dismantle the front end as the mechanics are intact.
Now when it comes to the radiator of the 451 smart. Is it inherently more complicated then cars of old where you flush the system, new thermostat, refill with antifreeze, even add a thicker radiator in the process. Or is there a more narrow scope of things to do with the 451 cooling system. I do see and electric draw through install, if nothing else there is space, would be insurance and may look cool with the bonnet off at the show and shine.
Have you customized your coolant system
