1 - 20 of 28 Posts
I remember some discussions here that it is will be impossible to make adapter plates so we can use 4 holes rims.
Owner of this smart did it.
3 lugs(PCD 112) to 4 lugs(PCD 100)
There is a big selection of nice 4-100 rims.
CUBE
I might be wrong, but I believe it is the same bolt pattern 3x112 but different offset, so adapters would work.
CUBE
I found this online a while ago and have photos stored on one of my drives. All I know that smart is 2003 pulse convertable and the owner is in Malaysia.
CUBE
I would have serious doubts about running on the road with 3x112 to 4x100 adapters.
I ran the idea up in a CAD package years ago and it is far from safe.
Is it not safe due to the spacing, IE 100? I am not familar with the way these patterns go. But it would seem like an extra bolt to hold it on would be way better. Again, I have no clue how this hole pattern stuff works, but if you could enlighten me, I would appreciate it. Thanks.:D
On the 3 to 5 stud adapters, 1 of the bolts goes all the way through the wheel, the adapter and the hub.
On the 3 to 4, the adapter is bolted to the hub and the wheel is bolted to the adapter.
No matter how you arrange the bolt patterns, 1 of the 4x100 bolts sits too close to 1 of the 3x112 bolt heads meaning there isn't enough material around 1 of the bolts to allow it to be safe.
If it was viable, we would have seen them for sale years ago instead of the 3 to 5.
That has me wondering why did they (smart) choose to go with three in the first place. Did they really worry about weight that much or are they not so bright like so many of us seem to think.
karl
Thanks. I was thinking kind of that way. But was not totally sure.:D
What if we plug the that bolt hole that's the closest? Now it should behave like a solid piece? :confused:
Then you'd be "stuck" with only 2 lugs...or 3 depending on how you look at it.
I'd rather stick to the 3-5 adapters. Its a shame that nothing is made for 6x112 :p
-Dan
Could the owner have exchanged smart for four hubs onto his 450? Does anyone know if they will interchange and what the bolt spacing is?
4x100 was my first choice for our adapters, but we also tried 4x114.3 (4x4.5) and 5x120. 5x112 is really the only pattern that works. Plus it sort of keeps it in the family by letting you use OEM or Aftermarket Mercedes Benz rims.
(And as mentioned, we have them in stock at $300 for a set of four, with hardware..)
Cheers,
Johnny
ZenSpeed.com
I know this is an old thread, but I want to wake it up. Has anyone considered using an offset bolt like they do for VW to Chevy adapters?
This would be the through bolt and the other 3 would not come close to stock holes. Just wonderin. I love TSW wheels and there is a set of 7X17s for sale I could get cheap. By the way, these are lug centric. Hub centric would be even better, with the centering ring making it run true.
1 - 20 of 28 Posts
