3d printed T90 Torx Tool
483 Views 5 Replies 4 Participants Last post by  CA2013ECE
A few years ago I needed a T90 Torx to change the 451 EV desiccant cartridge. The Germany version from McMaster was too expensive for a seldom used tool. Not wanting to buy the much cheaper versions made in an authoritarian country, I searched for the Torx specification and found ISO 10664. I modeled and 3d printed my own T90 Torx tool.
The first couple iterations worked, but wasn't the best. Anyway, it's time for another desiccant cartridge change. I made some changes to strengthen the tool and cleaned up the OpenSCAD file used to generate the 3d model.
The T90 Torx tool was printed on a Prusa Mini+, using PETG filament for better durability. The 3d model along with the OpenSCAD file can be found on https://www.printables.com/model/488690-t90-torx-tool
Tire Automotive tire Wood Synthetic rubber Gas
See less See more
  • Helpful
Reactions: 5
A 14mm hex bolt head with vicegrips clamped to the shank is a more elegant solution...
  • Helpful
Reactions: 1
Yeah, I've got an old 14 mm Allen wrench from an old Mercedes that I use.
I didn't know 14mm allen wrench also works. On McMaster, a US made 14mm allen key is only $11.12. Oh' well, it's a learning experience :)
Locking two 14mm (or 9/16”) nuts against each other to a bolt will also work and many of us will have those just laying around already.
Reactions: 2
That's a really good idea. I've never thought about locking two nuts together to function a hex key. We've went from a specialized T90 Torx, to 14mm Allen Key, to two 9/16" nuts. I feel like I am learning secret McGyver tricks :)
Reactions: 2
