As I mentioned in another thread, I removed the front panels to change the fan. It was long and annoying but I got through it.
Something interesting happened on reinstallation: the one T30 bolt in the 'sail' in front of the mirror (where the little passion emblem is) is having a VERY hard time screwing in.
On one side, it took WD-40 and a heavy hand. On the other (driver) side I had to stack a few washers under the bolt's floating washer to secure the panel.
Now, this is a regular T30 head bolt which goes into the Tridion's metal. It's (metric) machine thread, so there is NO reason for it to give me grief.
Opinions? Suggestions? Do I need to run a cleaner tap in there? It seems odd, this is the third time I've taken the panels off and I don't recall having this issue the previous times...
