1 - 2 of 2 Posts
I have a 2008 Passion. I just change my clutch actuator, and after a fresh start when I put it into reverse, the dash shows a blinking N, and no reverse. So I put it into drive, and the dash shows D. Then into reverse, and the dash shows a R. Now I have reverse. I can do drive first, then reverse for ever, but does this lead up to anything I should look out for?
You will likely need to reteach the transmission. Searching the forum should give exact details, but as I recall the procedure is to turn the key to the first position, hold the brake for 45 seconds and it should start figuring it's position out. If that doesn't do it, you might want to double-check the installation of the clutch actuator.
1 - 2 of 2 Posts
