So I bought a used pod set in the marketplace. The pods had been installed and when removed the wires were cut. I'm pretty handy with a soldering gun and wire stripper so I figured I could wire this thing up to my Smart pretty easily. There are 3 wires that go to the main harness, which the connector is located behind the speedometer. I saw that the pod has 3 colored wires, brown, black, and blue. I got some primary wire to lengthen the cut wires and pulled the speedometer. Unfortunately, the colors of the car wiring does not match the colors of the pod wiring. So I did a little sleuthing, and figured out the wires.
Here's the colors to hook up:
Pod blue wire to red/white harness wire
Pod brown wire to blue/violet harness wire
Pod black wire to brown harness wire
I debated for awhile on hooking the thing up because I'm sure that a wrong wire would cause some damage. I finally figured I would trust my research and went ahead and cut the harness plug, wiring it thusly. The harness wires are short, so I had to take some time prepping and soldering the wires.
I could see right away the clock was running, so I started the car and voila! Tach is working perfectly. It even lights up when the headlights come on like it should.
So if anyone needs this info here it is...
And thanks to magicbus66 for the pod!:laugh:
Andy
Andy
