1 - 2 of 2 Posts
Hey guys,
Just a friendly FYI for everyone struggling to get into the fuses in the glove box.
I've found that by avoiding the "thumb hole" provided, and going straight to the other end of the cover in the back of the glove box, you can easily push that to the right and then pry it forward. This should free the entire thing which you can then remove.
If you jam a flat screwdriver in the vertical slot on the right side of the fuse panel. That releases the catch and you can pull the fuse panel towards you and then down. You can access the whole panel below the glove box.
1 - 2 of 2 Posts
