1 - 14 of 14 Posts
Hello smart people. Our new 453 has stock headlight bulbs and I'm looking for LED drop in replacement bulbs that work with the CANBUS system and also fit with little or no modification. I did a search here, and I didn't have any luck finding anything Thanks in advance
My 453 has working LED headlights. To get them to work I had to modify the grommets to allow venting the fans.
I don't drive the car in the rain so I can't say for moisture, but the lights look great!
I'll have to pull the car out of the garage, take some pics, and make a thread. :)
The lights I used were Auxbeam H4 8000lm LEDs from Amazon. I modified the grommets by drilling a giant hole to them and screwing a medium sized medicine bottle into the grommets. This extra space allows some breathing room. I then drilled a small hole into the bottom of the medicine bottle for venting.
Discussion Starter · #7 ·
Thanks for the note. I live in the Pacific Northwest were rain is our middle name
Hoping to find an option where there is no risk of moisture problems
I stand corrected...
H4 HB2 9003 G7 Hi/Lo 6500K Philips Lumileds ZES LED Headlight Conversion Kit
Sorry for the large font, don't know why.
Anyway, these lights are fantastic, they
are extremely well made and also allow
you to change the length of the bulb
portion (not necessary) and shorten
the heat sink distance (necessary).
They colour matches the led DRL exactly.
Price is excellent. This is what should come
as standard when the LED package is ordered.
I installed the hikari Phillips version https://www.amazon.com/gp/aw/d/B077B3SNJR/ref=ppx_yo_mob_b_old_o0_img?ie=UTF8&psc=1
The bulb fitted fine but had to make a slight cut at the bottom of the cover to run the wire out for the ballast. Cut it slightly offset so the wires give the bulb a bit of torque tension to keep the bulb straight and locked in.
So far no moisture issues gone thru many rainy days and high pressure car washes. No heating issues so far either but haven't gone thru real heated summer yet. I'm not to happy with the beam pattern tho, here are some pictures. View attachment 41396
After 2 1/2 years, I had to change out our LED headlights due to intermittent flickering.
After removing, I noticed corrosion on the plug plus rust on the screws of the driver case.
They had no water resistant rating unlike the new set which are rated at IP68...
Beam pattern and brightness are excellent.
How about Sylvania ZXE bulbs. I used to run 2 sets in a 451. Lo and Hi beams are BOTH H4s. Lo grenades, swap out with Hi beam.. Tada!
Have to agree factory fitted headlights on the 453 is rubbish. In the UK on the 453 it is a MOT failure to use LED front headlights as the beam pattern is not correct for road use, it can blind oncoming traffic (compulsory MOT test = road worthiness of car testing every year, once three year old). What we can do on the 453 is fit 150% brighter bulbs for same wattage, costing around $22 a pair.
Example...Phillips night vision
There was a recall on the 453 that "disabled" the headlight adjustment. I just "adjusted" my headlights because of my 50lbs tube of sand in the back. A 1/4" Allen head does the trick. Sometimes I drive with the clearance lights, fog lights and rear outer LEDs funnin' with folks!
1 - 14 of 14 Posts
