1 - 9 of 9 Posts
So I have replaced all bulbs to LEDs inside and out. Success with all after a couple of different bulb tries, BUT I am experiencing an intermittent hyperflash. Really dont understand why. Tail, brake and DRLs are stock LEDs. I dont want to install resistors, they are dangerous. Is there a flasher relay I could change?
Snark is correct. The standard circuit is designed to flash at the slower rate when there is enough current draw. Incandescent bulbs draw a lot more current than LEDs. Without load resistors to draw more current, the circuit thinks the bulbs are blown and goes into hyper flash as an alert the a bulb is burned out.
How bout something like this? Where would it go? How many prongs? Just a thought.
XtremeAmazing 5 Pin EP27 FL27 Electronic Flasher Relay for Car Vehicle LED Turn Signal Light Bulbs Hyper Blink Flash Fix
  1. XtremeAmazing 5 Pin EP27 FL27 Electronic Flasher Relay for Car Vehicle LED Turn Signal Light Bulbs Hyper Blink Flash Fix
1 - 9 of 9 Posts
