1 - 4 of 4 Posts
As much work as it would be to remove the fan motor, I would replace it completely. removing the fan requires you to remove the front clip, radiator/condenser, and front header panel. Also need to refill the coolant and refrigerant. After all that work I would replace the whole fan motor
Hasn't someone put a fan on the front of the radiator and powered it with the original wires to avoid all that work? Or am I thinking of some other car.
1 - 4 of 4 Posts
