ED battery failures, the expensive $15,000 kind, happen because the 12 volt battery weakens or dies during periods of neglect ie not being driven on a more or less daily basis. So the high voltage battery tries very hard to keep the 12v battery fully charged but failing to do that it ends up killing itself. Same as if you left the headlights on etc.
The solution is to disconnect the negative post of the 12 volt battery and connect a 'float charger' to this battery to keep it fresh during your absence. So even if the 12 volt battery does die somehow on its own this will have no effect on that $15,000 high voltage battery. The hv battery will slowly discharge when connected but this can be estimated from experience. After 10 weeks my 2016 ED3 traction battery went from 85% down to 45% during temperatures ranging from 20*F > 35*F. If much colder is expected do NOT expect similar results.
See: "Case Studies Needed - ED Long Term Storage" in the "smart fortwo Electric Drive" forum for prior reporting.
