Does the 453 have a sight glass in the ac line? If not, how is refrigerant checked? A/C worked fine last year. Now blows no cold air at all.
As OliverB says, the defrost was used numerous times over the winter and the AC kicked on. So anyway, I'll try a local shop before making the long trek to Pittsburgh, the closest Mercedes dealer that will work on it. I think they have a good reputation with Smart. The local Mercedes dealer (State College, PA.) is worthless for anything but sales and turns up it's nose at Smart.Just a guess but since you admit to not using your a/c since last year, it is possible that some of your R-134a leaked out and the compressor is not coming on. Best way to get your system back in action is to have it recharged at a shop that has an R-134 charging station and can leak check your system. The A/C system should be turned on frequently, event in winter, to keep the compressors seals lubricated and prevent this sort of thing from happening.
For normal AC service any good shop should be able to check coolant charge level and for a leak.As OliverB says, the defrost was used numerous times over the winter and the AC kicked on. So anyway, I'll try a local shop before making the long trek to Pittsburgh, the closest Mercedes dealer that will work on it. I think they have a good reputation with Smart. The local Mercedes dealer (State College, PA.) is worthless for anything but sales and turns up it's nose at Smart.
I just hope it's not the freaking computer. It does blow hot air when I crank the temp up.For normal AC service any good shop should be able to check coolant charge level and for a leak.
What's it look like?Have you checked the thermocouple connection in the passenger footwell?![]()
OK. Thanks anyway. 🙃Sorry, that's on a 451...![]()
