hi guys so i ordered a new actuator for my 2009 smart. after i install it do i need to go to thw dealer to get it programmed.or relearn o anything like that?
oh really?? i dont see how it can hurt anything so ill give it shot thanx!The official answer is yes. However, several owners have not done that and the car seems to operate fine. Your call. <img src="http://smartcarofamerica.com/forums/images/SmartCarOfAmerica/smilies/tango_face_smile.png" border="0" alt="" title="Smile" class="inlineimg" />
Hello, Please provide an update on how you resolved this. Mercedes dealer near Asked me to pay $1900. I tried to avoid going to the dealership in the first place. I had a local mechanic did the repair on the Actuator, but we got stuck with the coding.hi guys so i ordered a new actuator for my 2009 smart. after i install it do i need to go to thw dealer to get it programmed.or relearn o anything like that?
Bluestone, in the very early days of arising actuator problems, one of the first advice given was always to disconnect the battery before taking off the actuator or "very bad things could happen." Never found out what could, because I follow this advice.Hello, Please provide an update on how you resolved this. Mercedes dealer near Asked me to pay $1900. I tried to avoid going to the dealership in the first place. I had a local mechanic did the repair on the Actuator, but we got stuck with the coding.
The actuator was actually repainted by a mechanic, but unfortunate when the car was put back together, there was a coding issue. Mercedes won’t release the necessary coding, but instead requested that the car be towed to them. They called me few hrs later stating that additionally they found other “issues”. In total, they are asking for $1900.Bluestone, in the very early days of arising actuator problems, one of the first advice given was always to disconnect the battery before taking off the actuator or "very bad things could happen." Never found out what could, because I follow this advice.
Now, when an actuator is "repaired", what was done to it? I had 2 instances of actuator problems back in those days. In 2010, I didn't know any better and had MB of Pittsburgh do the work for a healthy near $700.00 after a $200.00 labor discount. They actually replaced the broken one with a new oem. I learnt later that it was very much a walk in the park (un/screw 3 bolts, duh!!) to remove and instal actuators.
The second time was when I'd acquired Chewawa. Unicycle the owner was given a raw deal when his MB dealer had quoted in the $3K that he'd needed to "replace the tranny". When winter had thawed out, I took Chewawa's actuator apart. I found a few bits of broken, white plastic and thought maybe that was the problem. Cleaned and lubed the insides, and put it back in. Chewawa worked for a block and then started bucking like crazy, so I took it back to park. Got a used actuator from a forummer in Canada for $100, and when it came, I lubed the insides, put it back in, and all went well until today.
So I am curious to know what exactly is the problem that needed $1900 to fix.
Pardon the typo, it was replaced, not repainted.The actuator was actually repainted by a mechanic, but unfortunate when the car was put back together, there was a coding issue. Mercedes won’t release the necessary coding, but instead requested that the car be towed to them. They called me few hrs later stating that additionally they found other “issues”. In total, they are asking for $1900.
