I've gained a lot of info here but still coming up short on the correct way to wire an aftermarket head unit in my 2015 Cabrio.
The unit is an Alpine iLX-007. Crutchfield suggested a Metra 70-1784 adapter for the unit, but I also read elsewhere from people that actually installed an aftermarket unit used a Metra 70-1783. I tried the 1783 but got nowhere. I will recheck everything and use a meter tonight as I was a bit rushed. Crutchfield advised to switch the yellow and red around as well. Evilution advises that should not be the case but 'some creative' alternatives might be required since there is no ACC position.
So for those who have actually done it- What to do about the ACC wire and what adapter was used. Hopefully you can help me to get this wrapped up.
On a side note, has anyone removed the front roof trim on a Cabrio? Evilution has a guide for a coupe, not a Cabrio. I've removed the visors and 4 bolts but cannot get the outside edges loose. I managed to stuff the cables (for a mic and dash cam) but would really like to do it better.
