what happens to water that goes in the intake vent.....is there a water trap/drain between the neck and air filter where it drains out?
I'm sure there is a drain hole located most likely in the base of the filter box , since it draws air from the bottom of the air box .
thank you Joe for the detailed info, it is always nice to have someone go the extra mile and add a personal touch to a question/problem instead of being left hi and dry. some of us do have some limitations.
it is ALWAYS nice to talk to you and the goodwill goes a long way compared to something in black and white
Terry,
Great talking to you again, and I'm glad I could answer your question minus the sarcasm.
Good luck with those new rims.
Take Care
JL
From what I can tell, there is also a set of baffles and hoses inside the panels between the vent and air box. These baffles should be able to keep water out of airbox unless you’re submerged to the point that the vent is also under water, at which point you have bigger worries than just water in the intake.
