Ambient temperature reading -356. Does anyone know if this will affect performance or starting issues? Will not start unless pluged in even in summer. Tried New turbo, new glow plugs & sensor, new battery
Bump.
451 showing - - on the cluster instead of outside temp and A/C doesn’t engage therefore no cool air here in the south. I’ve searched all over this forum and googled all I can think of to find anything to do with the exterior temp sensor and it’s ties with the A/C system in the 451. If anyone could give any info on this your help would be greatly appreciated.
OP never stated if 450 or 451. If your car is a 451 the A/C will not run if the temp (real or indicted) is below 45 degrees or so. My guess is the outside air temp sensor is bad. :)
Tried New turbo, new glow plugs & sensor, new battery.
This bit would also mean OP is driving a diesel, which without a location is an even greater shot in the dark.
Reactions: jwight
Like most vehicles. Doesn't the smart cars AC compressor, function. When you use the defrost setting. Why below 45 degrees in the winter time.
Most cars , the AC will run during the defrost cycle. I would think smart works the same way. Defrost cycle is different than the a/c cycle.
