The reception on my after market radio has went completely down the drain recently.
Does anyone know the part number of the antenna booster behind the drivers side quarter panel?
I have and I've replaced the antenna and the antenna moint. The connection in the back of the radio is good and I have a direct ground I ran to the post near the battery.
Smart antenna is special as many cars with fibreglass or plastic.
These cars do not offer a good "ground plane" to mount the antenna on body.
Instead, manufacturers install "ground free" type antenna or if you prefer, a real dipole antenna
If you look closer at Smart' antenna, you will see double wires threaded in helicoidal pattern. That is the both parts of dipole.
So, it is not a good idea to ground the OEM antenna, nor a standard "ground plane" antenna.
Hope this help you
