Antenna mounts for smart fortwo
I did google/search this topic on here and various boards but everything I found was really old. I'm in the process of figuring out a mount for a quad band antenna on my 451 and right now it's looking like I will be using one of the rear bumper tow hook holes for the mount.
Will be similar to what Kitkatt1960 did here, http://www.smartcarofamerica.com/forums/f9/anybody-installing-ham-radio-smart-972/index8.html except I'm going to see if I can get the shop that does our SS muffler work to bend me up a custom bracket.
Two options, one is to get the threaded stud from smart madness and then get a bracket bent so that it positions the antenna just to the outside of where the rear tailgate drops. The second idea is to get one of the tow hook D ring style hooks that appear to be screwed together. I do have one on order from Hong Kong but it's still in transit. But the plan with that was to put that in the bumper, take off the D ring and have a basic L bracket bent and then just screw that into the part on the bumper. Would be a lot less bending work for the shop and might turn out to be a bit stronger since the other method is going to require two folds instead of one.
Other thing, has anyone sourced threaded rod that will work with the threaded holes in the smart bumper? Might just wind up building my own depending on availability.
For those looking into mounting a CB antenna, because I'm going multi band with scanners this wasn't really going to work out. I looked at this one. https://www.president-electronics.us/CB-Antennas/Magnetic-Antennas/New-York But on the cabrio there isn't really a good spot to stick it. The curved area between the windshield and top is not flat enough for a really solid mount and the tridion doesn't allow for a good angle for the antenna given it's limited range of motion. Though the antenna looks similar to the AM/FM mast on the smart it is a different thread size though I suppose you could McGiver the parts to work in that spot and then use a different antenna for VHF/UHF.
