I have some small Ukrainian flags that would be perfect for the Smart antenna. See attached. The problem is that on the road, the flag causes the antenna to bend backwards more than I'm comfortable with. I'm afraid that the antenna might break. Any suggestions on how to make this work? I've tried the flag by itself and also tried using a dowel rod attached to the antenna, but neither are good solutions.
Car Vehicle Land vehicle Wheel Tire
Looks good, the antenna won’t break. It’s pretty flexible. That flag, is pretty light weight.
Our st. Patrick’s Day flag were much bigger.
Tire Wheel Car Land vehicle Vehicle
It looks best at the top of the antenna for sure. I'd like to keep it there, but the antenna bends to almost a 45 degree angle at 40 mph or higher. Makes me nervous when I see it showing up right outside my window. Going down near the base would probably work, except it won't be as noticeable. I'll give it a try though.
Thanks for the suggestions.
Reactions: smark
