Can anyone tell me what brand of antifreeze can be used in a 2016 453. Thanks
Thanks that helps.Walmart says they have an OEM coolant for $51, or Prestone's equivalent for 11 bucks...
OE Replacement for 2016-2018 Smart Fortwo Engine Coolant / Antifreeze - Walmart.com
Arrives by Tue, Nov 9 Buy OE Replacement for 2016-2018 Smart Fortwo Engine Coolant / Antifreeze at Walmart.comwww.walmart.com
Just want to know what to buy when it comes time to add some.Curious minds want to know:
How do you know you are using the "wrong coolant"?
Any telltale sign?
What can go wrong if you are mixing in the "wrong coolant"?
E.g. top up the coolant level but have no idea what the existing coolant type/brand is?
I can only speak from a Big Rig perspective with 10's of Gallons of capacity... if you mix the wrong stuff in those, you can turn it to Jello and have a real problem. Hasn't happened to any of my trucks yet, but I've heard stories.Curious minds want to know:
Any telltale sign?
Looks like that I will be going with Prestone. Thanks everyone for the follow up.Khlam, I’m not necessarily endorsing OEM products, just the recommended type for the car.
I don’t have deep pockets so in many cases, the OEM versions are too expensive for my tastes too![]()
Looks like Zerex G-40 is the way to go, I spoke with the service person who only deals with Smart Cars where my car came from when new and always serviced there and he said just make sure the coolant is pink and not green like prestone because if you mix them all is fine until you turn off the car and when it cools down the coolant then turns into a jelly like substance. They had that issue with the newer models.Rock Auto...
2016 SMART FORTWO 898cc L3 Turbocharged Coolant / Antifreeze | RockAuto
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.www.rockauto.com
Just watch the shipping.
Zerex G-40 can be found at NAPA...
