1 - 8 of 8 Posts
The global transition to electric cars has been held up in the elevation by the lack of generic quick switch that works. All automakers would have sold far more electric vehicles had they been able to agree on one, two or three quick-switch standards.
As Mercedes considers the new Smart EQ Fortwo, hopefully, it study the idea.
Welcome to SCoA.
There is nothing GENERIC about today's purpose built HV Battery Packs.
PROPRIETARY automated machinery is required to support a "quick-switch station" - and to service their PROPRIETARY battery packs the electric-car makers would have to set up and install such equipment nationwide (next to their Supercharger stations?).
This would then no doubt create a Battery Pack standards war not unlike those with the VCR and how did that work out for Sony and their BETA?
Although originally discussed in 2012, Tesla still has this project on the "back burner" and continues to file related patents.
Wouldn't expect to see such an option for smart until battery swaps are accepted by mainstream builders like Tesla. I will mention this to my Grandchildren as I doubt we will see this anytime soon? :shrug:
September 16, 2017
https://futurism.com/tesla-patent-reveals-possible-plans-for-a-new-battery-swapping-station/
2014 Cabriolet bought in Sept 2016 with 6,470 mi
Replacing an entire pack has always and will likely always be a non-starter - they are too big and heavy to remove and replace.
Instead the packs should be made out of modules and the module should be a standard size. How each pack uses the modules can be different, but the modules themselves should be the same or come in a small range of sizes that weigh at most around 20lbs.
If the Smart car had at least one module that could be removed and replaced with a new one by the driver, you could keep a fully charged extra at home or in the car and seriously reduce the range anxiety for most people.
...Instead the packs should be made out of modules and the module should be a standard size. How each pack uses the modules can be different, but the modules themselves should be the same or come in a small range of sizes that weigh at most around 20lbs.
Thanks. That capability would permit EVs to be used as courrier vehicles, a “no-luggage” ride-share class or for long distance trips. Sales would then grow dramatically.
Can you mix old batteries and new batteries like that? It seems like a lot of engineering for a problem that doesn't need solving. The battery in the smart weighs over 400lb. A 20 lbs pack would give you less than 3 miles of range. Why not just equip the cars with DC quick charge so you can fully charge the car in 20 minutes? That's what all the other car companies are doing.
Discussion Starter · #7 ·
...Why not just equip the cars with DC quick charge so you can fully charge the car in 20 minutes? That's what all the other car companies are doing.
Yes, but what % of full charge does that 20 minutes provide?
Overtime, the industry needs to migrate to standard modules that are interchangeable and work in parallel or series in a form of rank in the vehicle. Some vehicle racks would hold more modules than others, but the modules would be generic to a single standard.
The modules would not be sold as part of the car; only the right to draw x number of modules. They would continue to be owned by the manufacturers or national third party EV battery module companies. Service stations (or EV support stations) would have large multi-module charging racks so drivers could simply stop to swap for fully charged modules and be on their way.
That would move the Nation from carbon-based to fully electric vehicles far more quickly. If we don’t create the standards, China surely will, given its greater government control of industry sectors.
1 - 8 of 8 Posts
