This weekend is the Field Day event for Amature radios across the country. If you get a chance to check out the local field day site, do so. Minnesota has declared that June 23 and 24 are Amateur Radio Operator recognition days.
I know, I was too busy packing (we're moving) and didn't get a chance to get out there with the club. (Cochise Amateur Radio Association, K7RDG) My father-in-law (NH6BF) was out there all day and said it was a good year for them. Next year I'll make it, I hope! (Or winter field day, who knows!)
Yinzer said:
Not really. The accessory electrical syatem you would be hooking the radio power to in the ED is exactly the same as the gas car save for how the system gets charged
This is really the information I was looking for. The electrical question was my biggest concern, as I was unsure the difference between doing this on an ICE car and on the EV. Since this radio is only 25W, I can probably wire it into the cigarette lighter. If I go any more though, I probably would need to do research on where to wire it. On my truck, it goes right to battery (with an inline fuse and cutoff switch).
I'm sure I can figure out the antenna issues. I'm thinking maybe a glass-through on the front window. Back window is out of the question because it's a cabrio. Either that, or a rear bumper lip mount of sorts.
Tony Margulis said:
What bands are you planning to use? 700cm/2M?
For now, yes, just 70cm/2m. Maybe I'll throw the HF in there at a later date, but I'd bet that unless it's QRP, I'd probably blow through a full charge rather quickly.
73 and thanks for the help everyone! N3RDO monitoring.
