661 - 671 of 671 Posts
Congratulations!
Realizing it's cold weather (30% off) degradation season - any noticeable impact on range???
Possibly a little, but with the widely variable temperatures here in Charlotte, it's hard to say. I drove 30 miles of mixed highway/city miles to work this morning in low 50s weather and it used 9.8kWh of energy according to OVMS, with a remaining SOH of 35.3%. Usually it would be 40-45%. I might be getting some reduced mileage.
On Monday morning the 24th, during a similar drive, I used 8.6kWh of energy but the temps for my drive were about 5 degrees warmer.
On the 17th, same drive, it was 35 degrees for my morning commute and I used 9.5kWh.
I guess I need to monitor it.
Just installed 4 x 185 55 15 tires on 4 x used steel rims approx $150 can. 4 used 185 55 15 take off less then 2400 km's $150 can, new valve stems $1.56, wheel paint free, install and balance $75.76, Total $177.32 can. or $281.60 US funds.
Even my wife states it's worth every penny
Now in regards to tire pressure for the new tires I found this calculator
Now this calculator take into consideration the size, and weight rating of the tire, and then calculates this against the manufacturers recommendation for amount of weight for the factory tire, and now computes the difference necessary for the new size of tire.
In my case the front psi went from 29 to 22 psi a reduction of 7 psi. The rear then went from 36 to 31 psi a reduction of 5 psi.
22 psi for the fronts is low.
The calculation is a 'static' measure, and turning the fronts with a 55 aspect ratio tire the sidewalls will roll...
Probably ok for a low aspect ratio tire like a 35 or 40.
the calculator has taken into consideration of the 55 series tire, however due to the extremely low weight per tire on the front end the program calculates this and takes this into effect.
