1 - 4 of 4 Posts
My rear window will not latch. i have taken it to the dealer and they fixed it. It is now out of warrenty. Please let me know of a fix I can do myself. The dealer in KC will charge me an arm and a leg. thanks
if they fixed it under warranty and it failed again they should repair it again, they should have fixed it permanently the first time. But try posting this in the tech section I haven't read anything about this issue but I'm sure you are not alone.
Hatch latch
Hi There, Do you keep the latch oiled? I use wd40 on all my latches because my driver side door had that problem and after giving it a good spray it loosened it up and it worked again.
1 - 4 of 4 Posts
