Give your Smart a backup camera that integrates into the existing license plate light. All cables and instructions included $50 plus shipping
Specific vehicle reversing camera for the following models:
- SMART FourTwo Coupé (C451) (2007 -)
- SMART FourTwo Cabrio (A451) (2007 -)
ZENEC is expanding its accessories range by twelve vehicle-specific rear view cameras from the E> GO series: the very high quality EL cameras offer excellent image quality as well as the practical features. The compact wide-angle cameras replace the factory installed module for license plate light - installation is straightforward: remove license plate light, install camera, run cable to the control unit, ready. A separable 3-part system cable with 5.0 m length and waterproof connectors system simplifies the cabling. Each camera integrated discreetly in the respective vehicle, the original car appearance is maintained. the EL cameras use to license plate illumination, the same lamps as the target vehicle - depending on the car model thus an incandescent lamp or LEDs. These E> GO cameras only the best components are used: for example, high-end CMOS sensors with great color fidelity that can detect very faint situations because of their high sensitivity. Due to a horizontal angle of 110 ° also objects which are very close and / or located at a shallow angle to the car are clearly imaged. The parking and maneuvering is even easier with distance guide lines that are integrated in the image. Thanks to the special camera housing - built according to protection class IP69K, the highest standard for contact, foreign, water and moisture protection - all models are optimally protected against water and dust. High quality materials and rugged construction ensure a high weather resistance and connected to a long life. Due to the high operating temperature range of -20 ° C to + 75 ° C, there is always a clear view to the rear
A 2017 thread showed this video and at 6:14 of the video it shows a back up camera integration with the Smart Highline radio.
Has anyone else gotten a back up camera to work with this radio?
Also shows a neat push button start at 4:37. and a type of key fob at 5:46.
SMART MADNESS what say yee on these two mods. I would for one would pay
Well I don't have the Smart highline radio but I got a very inexpensive 7" Android touchscreen radio that has a back up camera, it works great.
