Went through diagnostics to find battery drain. Disconnected battery (-) and measured amp draw. After turning key on/off and waiting for things to quiet down, had a rather steady 145 mA. Tested several times - same result each time.
Reconnected battery and began going through each fuse. Found the culprit at fuse #12 - "Switches strip, on-board diagnostics socket, turn signal lamps, transmission control unit, exterior lamp switch".
Only problem is that I had to have door open in order to test. Any idea if this can be influencing the test?
When I put the leads on the fuse connection, the car chirps, there are a few hums and sits around 150 mA. After a few seconds, it drops to 100 mA, then drops to 93.5 and holds constant (as long as I can maintain contact, which is hard in that position).
And ideas? Dread taking it to the dealer as my experience to this point has not been po$itive.
