1 - 10 of 10 Posts
I have a smart prime 2016, the car has only done 14000 and my timing belt seems to have a rip on the edge. Is it still safe do drive the car or am I worrying for nothing. I have attached some photos. I would have thought this model would have a timing chain. Help would be much appreciated.
65457
Automotive tire Wood Tread Rim Tints and shades
65458
65459
Why does that look like the poly serpentine belt?
The edge shredding suggests something out of alignment (bearing failing?) causing pressure on the left side???
I’d caution against driving it far as if the “accessory” belt breaks serious damage (engine overheating) may occur...
Thankfully that is indeed a serpentine belt. I don't have a diagram on me at that moment, but I believe the important accessories it should go around are the alternator and water pump. The car can still drive for a while without the alternator, but you'll almost immediately overheat without a water pump.
It is abnormal for a belt to fail so soon. Make sure the pulleys are aligned and aren't damaged. I would get that fixed as soon as possible because that belt will soon be close to catastrophic failure.
Considering that several years ago, the serpentine belt on my 2016 was ripped in half, leaving the other half on a road god knows where, by a stone or piece of cement or something getting lodged between it and one of the pulleys, and I was still able to drive it to my dealer about an hour away, I'd say that missing a small piece probably wouldn't raise any alarms to me about potential for catastrophic failure. But either way, I'd still try to get it fixed ASAP.
Sent from my KB2005 using Tapatalk
A multi-ribbed v-belt can never function as a timing belt, as v-belts can slip during operation due to various factors ie. water, tension, object temporarily caught in the belt, etc. My multi-ribbed belt did the same thing, maybe the bottom cover isn't protective enough.
1 - 10 of 10 Posts
