Locksmith capabilities and equipment vary. You would need to ask them. Least hassle and time wasted is tow it to the smart dealer and get two keys and programming. Otherwise, you remove the SAM and send it to SOS and wait. What is your time worth?
Thanks for your reply. Does that mean there are some locksmiths that could actually create a key without any to work with? Wondering if it's worth my time to call any. At this point, my time is definitely worth saving 1/2 the cost of the dealer/new SAM route. However, even that's pretty expensive and somewhat time-consuming, so I'm hoping there might be an even better way.Locksmith capabilities and equipment vary...
I have never used a locksmith so I have no knowledge of what they can or can not do. If you tow the car to the dealer they will order the key blanks cut by VIN and the key fobs, then program them to the existing SAM. There is a smart service bulletin that details the procedure.Thanks for your reply. Does that mean there are some locksmiths that could actually create a key without any to work with? Wondering if it's worth my time to call any. At this point, my time is definitely worth saving 1/2 the cost of the dealer/new SAM route. However, even that's pretty expensive and somewhat time-consuming, so I'm hoping there might be an even better way.
Thanks, this was HUGE for me knowing there's a relatively painless way to do this. After reading about $1,500+ SAM replacement posts, this is a huge relief....If you tow the car to the dealer they will order the key blanks cut by VIN and the key fobs, then program them to the existing SAM. There is a smart service bulletin that details the procedure.
So, the keys that come from the smart factory are just the metal blades? I'd be buying the fob separately, either from eBay or the dealer? I'm asking because if I want to have the dealer do the service but have more than one key, I'm wondering if I should buy two blanks on eBay first, bring them to the dealer and have them get the cut blades from HQ and program my new fobs after swapping out the blanks for the cut blades. Don't want to have to pay $200 per key (or whatever) if I can do it for $50 each off eBay (plus programming).~ There Will Be Happy Days Again ~ The Misery Will Pass ~
1) Go to the Smart Dealer with the VIN and order the Set (they come as two) all are pre-cut blanks sent from the Factory in Germany to match your Car... $50.00
2) Buy the EBAY Fobs to get the button sets. You will have no need for the blanks on them. Vary easy to put your new cut blanks on them...
3) Send your SAM and the fobs you just bought to "SOS" to have the Fobs re-programed to YOUR SAM Unit...
4) Pay and wait for their Return to you...
NOTE: Verify over the Phone with "SOS" what you plan to do. with their OK, execute your Plan...
Date: December 7, 2012
Order No.: SM-B-80.00/02a
Supersedes: SM-B-80.00/02, August 8, 2012
Group: 80.00
Revision a: Revised with Additional Process Steps.
SUBJECT:
MY-All, Model 451 Procedure to Request SAM Password After Customer Loses All Existing Keys
When learning a new key into the SAM of Model 451, all existing keys must be present. For situations where the customer needs to order new key after losing all existing keys, you can request a special password that allows the SAM to learn new keys without any old keys being available.
The customer must have the following documentation before you can proceed with the request:
^ Valid vehicle registration with the customer name shown as the owner ^ Valid vehicle title with the customers name shown as the owner or lessee if vehicle is owned by a financial institution 1. Create a PTSS case for the vehicle with the symptom: Overall Vehicle//Safety and Locking System//Locks/locking/remote closing mechanism/Nonfunctional. 2. In customer complaint enter: Customer lost all original keys. 3. In workshop findings enter: Need password for SAM to learn new keys. 4. Ensure RO field is filled out and matches the RO for the spare part key order. 5. Attach clear and legible copies of both proofs of ownership documentation stated above. 6. You will receive in return a password for use in DAS version 11/2012 and later that will allow you to program key transponder codes in the existing SAM control unit.
