21 - 28 of 28 Posts
Super weird, I’ll have to try it out.
have you looked at the wiring coming from the SAM unit to check there was no corrosion or deformation/melting of the plug? There’s also another plug that plays a part, it’s referenced in WIS, two spots actually, at the odb2 port and just below it on the center stack, close to the floor.
I literally pulled the dash out and looked at every single connection. Everything looked like it was in order. It was so frustrating. I do believe now it was a software issue. Once it fully functional powering from the lighter, I was so done with it. It was such a simple fix. I did go to Mercedes of San Diego for the recall fix, they included a full inspection including software scan and found nothing! Its my daily commuter car. No issues at all since.
Ok, interesting. I’m going to do some quick tests, but I think I’m going to do the following:
But only powering the one leg that goes to the blower motor, and I get to reuse the existing 25a fuse. Running it off the 10a or 15a fuse for the cigarette lighter bothers me a little bit, this keeps it looking tidy. I hate ripping up wiring in cars, especially German ones.
I agree, I used wire taps made for 12 volt current. So the one wire that lead to the fan, I crimped an end cap on it to keep it from touching anything in case the car decided to re-power it. The route your going is way beyond my technical know how, update us so others can maybe use that route option.
For sure, so luckily the blower circuit is the easiest thing i've seen, i've found that there's no continuity between fuse 4 and the fan itself. i'll have to pull down the SAM unit and check
63104
F4 is the fuse #4 and there's no connection/continuity between it and the fan itself, its a bit confusing how its run, but it goes from the SAM, past the ODB2 connector, down the side of the center console/stack, there's a connector X85/10 that's attached behind the center panel, from there it goes up to the fan. i'm going to start checking continuity. id love to solve this for everybody :)
So, I pulled down the SAM unit and at first it seemed like there was no power going to n11/1 which is the red/grey wire going out towards the fan. Tested everything from the fan back to the Sam after trying to pull out the whole plug for n11/1 and still didn’t have any luck, stuck my probe into the back of the plug and boom I had 12v and continuity to the first hop.
plugged everything back in, no fan...
then like 30s in, I heard a relay click under the dash and boom the fans kicked in.
I think I had two issues? Maybe the reason the plug on the back of the Sam was so stuck in there was maybe the wire had melted? Or something? I still couldn’t get it out... bit me jiggling things around maybe helped. There are two relays that touch the HVAC, eventhough everything else was working fine.
I don’t know, whatever, I’m happy it’s working now.
Sweet, it worked out. Keep an update. I pulled and plugged and used my mutimeter gage. And it never switched back on for me. Still running tho. I only really need 3 more years before I retire. And with me teaching from home the rest of the year. I am sure it will last, hopefully! Glad to hear your back on comfortable driving.
Having the same issue with my fan blower not working.
-Replaced the fan blower, no luck for a while driving home on the 3 hour trip for the part then after a hour of driving the fan kicks on for about 2 weeks of being powered on and off. Now the new one is not working.
-(Old Fan)Replaced the fuse, the plastic part of fuse #4 was slightly melted but the fuse was ok. No luck
-Checked every other fuse, all ok
-Tried unpluging and plugging in fan, no luck
-Havent checked the relays yet. No clue where they are located for the AC fan
-Wiring all looks ok.
I'm thinking of just rerouting the power from the lighter but I got no electrical experence with wiring so mehhh. Some help?
US 451 2012 smart fortwo
21 - 28 of 28 Posts
