I have been having issues with my left break/turn light. I changed out the light bulb and i also changed it to the right and it works. What else can be wrong with the light? I’ve tried everything already. Any suggestions?
I have the same situation, left rear brake light and turn signal fail. I got the same advice, too--replace the bulb carrier. I did, and it did not solve the problem. However, I have never checked the fuse. And I also see there is also a relay, called Relay A, specifically for the left brake and turn signal!
Could one of these be the problem? Others here have suspected a grounding problem---how can I check for that?
1 - 8 of 8 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
