1 - 15 of 15 Posts
When was the last time the brake fluid was flushed? Bad brake hose(s)? Fluid level okay? If not find out where it's going.
Good luck.
No brake fluid anywhere? Many of the brake likes and the ABS pump are hidden under the belly pan. It’s unusual to have air introduced to the brake lines without seeing some kind of leak.
That being said, the master cylinder might also be going, though I would be shocked if that were the case with only 30K miles.
Hello all, I have a 09 smart, where the brake pedal goes down about 4 inches before catching and stopping the car. Does not feel spongy. Any thoughts on the problem. I don't recall seeing this before
The 451 uses rear drum brakes. If these should get out of adjustment it can cause the symptoms you are describing. They are supposed to self-adjust when one applies the brakes while backing up. Some peoples driving routine may not involve backing up, or possibly the self-adjusting mechanism has seized up.
Try driving back and forth a number of times making sure to apply the brakes firmly in the reverse direction and see if that results in the pedal coming back up to its normal height. If not, then I'd pull the rear drums to check the adjuster mechanism.
Since you state the brakes are firm, not spongy, I don't think you have air in the system as some are implying.
~toaster
I don't believe that's true re: the abs pump. I've been bleeding my brakes for a couple of years with no issues and no ABS pump recycling. I do use a one man pressure bleeder, but I don't think that makes a difference.
2014 EV Coupe 20,000 miles
2014 EV Cabriolet 18,500 miles
Maybe with an ABS pump issue, it may be necessary to have a dealer clear out any air and maybe the thread starter has an ABS issue, but for routine brake service, bleeding, etc. I don't think there is any need for a STAR machine to be involved. I certainly had no need for one. Would be nice to get the official word on this.
Just replaced the front pads/rotors at 33k. Noticed the brake pedal travel is more than before. Brakes work fine but I don't like all that pedal travel. Brake fluid is at the top mark.
I tried working and handbrake and service brake then backing the car up and down the driveway. At some point, the pedal travel was almost gone. But after sitting for a few minutes, the long travel returned.
Have you changed your brake fluid? Bleed the brakes. moisture in your system.
1 - 15 of 15 Posts
