…have you checked the owners Bible to see if that circuit is protected by a fuse???…do you have power at the plugs???…are the bulbs blown????
jetfuel…so many questions…
no power to front or rear turn signal or brake light on right side of car. tail and park lights work fine. indicator on dash doesn't light up for right turn either. something must control all.…have you checked the owners Bible to see if that circuit is protected by a fuse???…do you have power at the plugs???…are the bulbs blown????
no power going to plugs on right side front or rear.Welcome to the forum. Replacing the bulbs, would be my first thought. My rear lights, were always burning out. Use a standard Sylvania 1157 light bulb.
also no right side emergency flashers either.no power going to plugs on right side front or rear.
