My rubber seals on my '09 cabrio's hatch glue themselves to the body. This usually occurs after the car has sat for a while and the hatch not opened. If I pull hard enough while triggering the latch, the seals unstick. To compound the problem, I have rheumatoid arthritis, and it's painful to put that much of a load on my fingers.
I've never had a problem with my coupes, but then, after you lift the window, you can get a much better grasp on the top of the hatch.
I've scrubbed down the sealing surface with soap and water and alcohol; treated the seal area with WD-40, brake cleaner, petroleum jelly, talcum powder, and a few other items.
Has anyone else had this problem?
Cheers and thank you, Bob
